Bike Trainers
Smart Bikes
Bike Trainer Bundles
Indoor Cycling Accessories
Parts and Components
KICKR smart trainers
The KICKR lineup turns any bike into a connected indoor training studio. From the flagship KICKR to the value KICKR CORE 2 and the no-cassette KICKR ROLLR, every KICKR controls its own resistance, broadcasts accurate power, and rides in Zwift, TrainerRoad, and the free Wahoo app. This guide breaks down each model, how they compare, full specifications, and the questions riders ask most.
Wahoo KICKR smart trainer
Direct Drive
The benchmark direct-drive trainer
$1,299.95
A 16 lb high-inertia flywheel gives the KICKR its signature realistic road feel, while Wi-Fi Race Mode keeps you sharp in virtual races.
The trainer that defined the category. Top-tier 2200 W power, ±1% accuracy, 20% grade range, near-silent operation, and built-in side-to-side AXIS feet — on a fixed, rock-solid base.
2200W Max Power
±1% Accuracy
20% Max Grade
16lb Flywheel
47lb Weight
A heavy flywheel stores momentum for a smooth, realistic ride that feels like rolling on the road rather than spinning against a brake.
Wi-Fi Race Mode
Built-in Wi-Fi broadcasts power and data up to 10× faster than standard wireless, cutting latency so resistance and your on-screen position react instantly.
Side-to-side AXIS feet
Swappable AXIS feet allow up to 5° of lateral movement, taking the edge off a rigid indoor setup without a separate motion platform.
Auto-calibration & quiet drive
Belt-driven electromagnetic resistance runs virtually silently and calibrates itself, so the trainer stays accurate with no spindown routine.
Wahoo KICKR CORE 2 smart trainer
Best Value
KICKR CORE 2
Direct-drive performance, less outlay
$899.95
The CORE 2 now ships with integrated Wi-Fi and a pre-installed cassette, putting genuine direct-drive training within reach of most riders.
It trades the flagship's last few watts and a half-percent of accuracy for a much lower price, while keeping the quiet, accurate, app-controlled experience that makes a smart trainer worth owning.
1800W Max Power
±2% Accuracy
16% Max Grade
Wi-Fi Built-in
30lb Weight
Now with Wi-Fi & a cassette
The CORE 2 adds integrated Wi-Fi with automatic updates and ships with an 11-speed 11-28 cassette pre-installed, so it's ready to ride out of the box.
Broad drivetrain compatibility
Compatible with 8- to 13-speed drivetrains using Shimano HG and optional SRAM XD/XDR or Campagnolo freehub bodies, plus QR and thru-axle hubs.
1800 W, 16% grade
Up to 1800 W of resistance at ±2% accuracy and simulated grades to 16% — plenty of headroom for the workouts and routes most riders train with.
Multi-app, multi-connection
ANT+, ANT+ FE-C, Bluetooth (up to three simultaneous connections), and Wi-Fi keep it talking to Zwift, TrainerRoad, and the Wahoo app at once.
Wahoo KICKR ROLLR smart trainer
Wheel-On
Hop on any bike, in seconds
$999.95
A dual-roller design with a front-wheel clamp means no removing the wheel and no cassette to match — roll any bike on and ride.
The ROLLR blends the natural feel of classic rollers with smart resistance and a stabilizing clamp. It's the fastest setup in the lineup and the most bike-agnostic, ideal for warm-ups, shared bikes, and quick sessions.
1500W Max Power
10% Max Grade
Any Bike Fit
No Cassette
250lb Max Rider
No wheel removal, no cassette
The rear wheel rests on dual rollers and a front clamp holds the bike upright, so there's nothing to unbolt and no drivetrain matching — setup takes seconds.
Fits virtually any bike
Accommodates tires up to 2.1 in (53 mm) and a 950–1100 mm wheelbase, works with disc and rim brakes, and accepts all drivetrains with no modifications.
Onboard power, 1500 W
Estimates power onboard to within ±1% of an external power meter, with up to 1500 W of controllable resistance and grades simulated to 10%.
Natural, roller-style feel
The rear wheel is free to move, giving a livelier, more outdoor-like ride than a fixed direct-drive trainer while a clamp keeps you safely upright.
Also in the KICKR family
Beyond the trainers above, Wahoo builds two all-in-one smart bikes for riders who want the trainer and the bike in one.
Wahoo KICKR BIKE PRO
KICKR BIKE PRO — $6,499.99
A fully integrated smart bike with electronic shifting, a physically tilting frame for climbs and descents, and adjustable fit. No bike of your own required — it is the bike.
Wahoo KICKR BIKE SHIFT
KICKR BIKE SHIFT — $2,999.99
A more accessible all-in-one smart bike that keeps the immersive KICKR BIKE experience and adjustable fit at a lower price, with grade simulation handled in the app.
Compare the KICKR trainer lineup
How the four core KICKR smart trainers stack up, feature by feature.
Feature comparison between KICKR, KICKR CORE 2, and KICKR ROLLR
Feature KICKR KICKR CORE 2 KICKR ROLLR
Price (USD) $1,299.95 $899.95 $999.95
Drive type Direct drive Direct drive Wheel-on (rollers)
Max power 2200 W 1800 W 1500 W
Power accuracy ±1% ±2% ±1% of ext. meter
Max simulated grade 20% 16% 10%
Realistic motion Side-to-side AXIS feet Fixed base Rear wheel free on rollers
Wi-Fi & Race Mode Yes Wi-Fi (no Race Mode) No
Cassette included Yes (11-spd) Yes (11-spd) Not needed
Setup speed Moderate Moderate Fastest
Trainer weight 47 lb 30 lb 50 lb
Max rider weight 250 lb 250 lb 250 lb
Best for Racers, road feel Value, most riders Any bike, quick setup
Wahoo vs. the field
How the Wahoo KICKR platform compares with Van Rysel, Tacx, and Elite — where Wahoo leads, and where rivals have reached parity. Headline specs reflect each brand's current flagship direct-drive trainer.
Detailed feature comparison between Wahoo, Van Rysel, Tacx, and Elite flagship trainers
Feature Wahoo Van Rysel Tacx Elite
Brand & ownership Independent · USA Decathlon brand Garmin-owned Independent · Italy
What sets Wahoo apart
Wi-Fi Race Mode (low-latency) Yes No No No
Ecosystem for bike + run KICKR + KICKR RUN — — —
Climb, fan & smart-bike ecosystem CLIMB · HEADWIND · BIKE — NEO Bike Rizer · Sterzo
Built-in trainer motion Side-to-side (AXIS feet) — Side-to-side Add-on (Rizer)
Lineup price span $899.95–$6,499.99 Budget–mid Mid–premium Mid–premium
Parity — what the field shares
Power accuracy (flagship) ±1% ±1% ±1% ±1%
Open standards (FE-C, FTMS) Yes Yes Yes Yes
Use without a subscription Yes Yes Yes Yes
Zwift · TrainerRoad · Rouvy Yes Yes Yes Yes
Built-in Wi-Fi Yes Yes + Ethernet Via adapter Yes
Max simulated grade 20%* 27% 25% 24%
Smart bike option KICKR BIKE — NEO Bike Plus Yes
Where rivals stand out: Tacx leads on road feel (virtual flywheel and road-surface simulation) and Garmin Connect integration; Van Rysel offers standout value and the only standard built-in Ethernet port; Elite matches Wahoo's built-in Wi-Fi. *Competitor flagship grades (Tacx 25%, Elite 24%, Van Rysel 27%) exceed the KICKR's 20% — Wahoo matches them only with the add-on KICKR CLIMB.
Technical specifications
Full side-by-side specifications for the Wahoo KICKR smart trainer lineup.
Detailed list of technical specifications for KICKR, KICKR CORE 2, and KICKR ROLLR
Specification KICKR KICKR CORE 2 KICKR ROLLR
Type Direct drive Direct drive Wheel-on roller
Resistance Electromagnetic, belt drive Electromagnetic, belt drive Electromagnetic
Power accuracy ±1% ±2% ±1% of external power meter
Min simulated grade -10% -10% -10%
Flywheel 16 lb High-inertia (belt drive) 10.5 lb / 4.7 kg
Realistic motion Side-to-side AXIS feet (up to 5°) Fixed base Rear wheel free on rollers
Cassette 11-speed 11-28 included; upgradeable to 12-speed 11-speed 11-28 included; 8–13 speed compatible Not required (wheel-on)
Hub compatibility 130/135 mm QR, 12x142, 12x148 thru-axle 130/135 mm QR, 12x142/148 thru-axle Any bike; tires up to 2.1 in, wheelbase 950–1100 mm
Connectivity ANT+, ANT+ FE-C, Wi-Fi, Bluetooth, Direct Connect ANT+, ANT+ FE-C, Wi-Fi, Bluetooth ANT+, ANT+ FE-C, Bluetooth, Direct Connect
Race Mode Yes (Wi-Fi) No No
Trainer weight 47 lb / 22 kg 30 lb / 13.6 kg 50 lb / 23 kg
Max rider weight 250 lb / 113 kg 250 lb / 113 kg 250 lb / 113 kg
Warranty One-year limited Two-year limited Two-year limited
Charging / power AC power adapter AC power adapter AC power adapter
Training with the Wahoo App
The free Wahoo app sets up, updates, controls, and records every KICKR trainer. The trainers are also open standards, so they work natively with Zwift, TrainerRoad, and other ANT+ FE-C and Bluetooth apps.
Guided setup & firmware
Pair the trainer, run any firmware updates, and start riding. The app handles calibration and keeps the trainer current automatically.
Trainer control & ERG mode
Set a target wattage and let ERG mode hold it for you regardless of cadence, or switch to level and simulation modes for free riding and grade-following.
Structured workouts
Execute interval and threshold workouts with the trainer automatically driving resistance through each block, adjustable on the fly.
Ride with Zwift, TrainerRoad & more
Every KICKR speaks ANT+ FE-C and Bluetooth FTMS, so it drops straight into Zwift, TrainerRoad, Kinomap, Rouvy, and other connected platforms.
Connected ecosystem
Add the KICKR CLIMB grade simulator and KICKR HEADWIND fan and control them alongside the trainer for a fuller indoor experience.
Activity history & analysis
Review power, cadence, and heart-rate data from each session and track how your indoor and outdoor riding builds fitness over time.
KICKR smart trainers — what you need to know
Answers to the most common questions about Wahoo KICKR smart trainers, drawn from Wahoo Fitness.
What is a smart trainer?
What is the difference between a direct-drive and a wheel-on trainer?
Which Wahoo KICKR trainer is the best value?
How accurate is the power measurement on Wahoo KICKR trainers?
Do I need a cassette to use a Wahoo direct-drive trainer?
What is the maximum incline these trainers can simulate?
What is Race Mode on the Wahoo KICKR?
How much do the trainers weigh, and what rider weight do they support?
Does the KICKR ROLLR work with any bike?
Do Wahoo KICKR trainers require a subscription?
What accessories work with the KICKR ecosystem?
The indoor training guide
How riders use smart trainers to train with precision year-round, what separates a serious training trainer from a basic one, and when indoor riding is the right call.
How riders train on a smart trainer
The control a smart trainer gives over resistance unlocks training that's hard to do on the road. These are the methods riders rely on most.
ERG-mode intervals
In ERG mode the trainer holds a set wattage no matter your cadence, so you can hit precise interval targets without watching a screen. It's the most repeatable way to execute structured threshold and VO2 work.
Virtual riding & racing
Apps like Zwift translate gradient into resistance in real time, so climbs feel like climbs. Race Mode on Wi-Fi KICKRs cuts latency for sharper, more responsive virtual racing.
FTP testing
Accurate, repeatable power makes the trainer the ideal place to test functional threshold power. Re-test every few weeks to keep training zones aligned with your fitness.
Recovery & sweet-spot rides
Dial in an exact, controlled effort for easy recovery spins or sustained sweet-spot blocks — no coasting, no traffic, no junk miles.
Climb simulation
Simulation mode plus an optional KICKR CLIMB recreates long climbs by changing resistance and physically tilting the bike, letting flatland riders train ascents.
Warm-ups & openers
A quick-setup trainer like the ROLLR is perfect for pre-race warm-ups and day-before openers where you want a controlled effort with minimal fuss.
What distinguishes a serious training trainer
Not a formal category, but trainers aimed at committed cyclists tend to share these characteristics.
Features that distinguish a serious training trainer from basic models
High Power AccuracySerious trainers measure power to within ±1–2%, so workout targets and FTP tests are trustworthy and repeatable.
Direct-Drive DesignMounting the bike onto a built-in cassette gives quieter, more accurate, higher-power performance than wheel-on trainers.
High Power CeilingA 1800–2200 W ceiling ensures even the hardest sprints aren't capped by the trainer.
Steep Grade SimulationSimulated grades of 16–20% let virtual and recorded climbs feel real.
Open ConnectivityANT+ FE-C and Bluetooth FTMS support means the trainer works with any major training app, not a single ecosystem.
Realistic FeelA heavy flywheel reduces the dead, static feel of cheaper trainers on long sessions.
Indoor vs. outdoor riding
Indoor training is a powerful complement to outdoor riding, not a replacement. Both build fitness; the trainer adds precision, consistency, and convenience that the road can't always offer. Here's when reaching for the trainer makes the most sense.
Bad weather & short days
Rain, snow, heat, or darkness make outdoor riding impractical or unsafe; the trainer keeps training on track year-round.
Precise workouts
Trainers excel at controlled intervals and exact power targets that are hard to hold outdoors with stops, descents, and traffic.
Time efficiency
No coasting and no junk miles means a 45-minute indoor session can deliver more training stress than a longer outdoor ride.
Safe high-intensity efforts
Maximal sprints and all-out intervals are safer indoors, with no intersections, descents, or road hazards to manage.
Which KICKR is right for you?
There's a KICKR for every kind of rider and budget. Match the trainer to how you ride and what you want indoor training to feel like.
The virtual racer
For Zwift racing where every second counts, the KICKR with Wi-Fi Race Mode broadcasts data up to 10× faster so resistance and your position react instantly.
The value-focused trainer
The KICKR CORE 2 delivers genuine direct-drive accuracy, quiet operation, Wi-Fi, and an included cassette for $899.95 — the sweet spot for most riders.
The quick-setup rider
If you switch bikes often or want to roll on and warm up in seconds, the KICKR ROLLR needs no wheel removal and no cassette to match.
The no-bike-needed buyer
Want an all-in-one with adjustable fit and electronic shifting? The KICKR BIKE PRO and KICKR BIKE SHIFT are the bike and the trainer in one.
The quiet-space rider
Training in an apartment or shared space? Every KICKR runs on near-silent electromagnetic resistance, and at 30 lb the CORE 2 is light enough to move and store between sessions.
Start with the CORE 2 if you
Want the best balance of price and performance. It covers everything most riders need — accurate power, quiet direct-drive feel, Wi-Fi, and a cassette in the box — without paying for flagship features you may never use. It's the easiest KICKR to recommend.
Step up to the KICKR if you
Race virtually and want the lowest latency, or simply want the most realistic road feel and the highest accuracy and grade range in the lineup. The KICKR adds Race Mode and the signature 16 lb flywheel.
What riders are saying
Illustrative feedback reflecting common themes from riders using KICKR trainers. These quotes are examples and are not sourced from Wahoo Fitness.
ERG mode on the CORE 2 just holds the watts and I execute the workout. It's the most consistent training I've ever done, and it was quieter than I expected.
Sam Cat 3 racer, winter base training
I share a trainer with my partner and our bikes are totally different. The ROLLR means we just roll on and ride — no swapping cassettes, no fuss.
Marcus Commuter, two-bike household
