Zwift Ride V1 Smart Frame
$1,400.00
Upgrade to Zwift Ride Smart Frame and transform your Zwift Ready or Zwift Compatible KICKR smart trainer into an always-ready, all-in-one smart bike. Built-in handlebar controls Zwift and enables customizable virtual shifting. Zwift Ride Smart Frame is easily adjustable, making it perfect for everyone at home. Keep your outdoor bike ready for the outdoors and upgrade to an all-in-one indoor cycling solution that’s always ready to go.
  • Rider Fit Range: 4 ft 10 in - 6 ft 6 in (147-198 cm)
  • Saddle Height: 22.5-34.1 in (57.1-86.5 cm)
  • Stepover Height: 28.7 in / 73 cm
  • Maximum Rider Weight: 264.6 lb / 120 kg
  • Crank Length: 160 / 165 / 170 / 172.5 / 175 mm
  • Product Dimensions: 110 x 43.2 cm
  • Product Weight: 25.5 kg
  • Drivetrain: chain (KMC Z1 narrow 3/32 in)
  • Handlebar Controllers: rechargeable, about 20 hours per charge (USB-A, 5V, 1A)
  • Takes up less room than a bike on a trainer and packs away between rides
  • Sets up on your own with the included frame key and a compatible smart trainer
  • Adjusts for riders from 4 ft 10 in to 6 ft 6 in (147-198 cm)
  • Handlebar controls queue workouts, fire PowerUps and send RideOns without pausing
  • Silent virtual shifting with a customizable gear setup
  • In the box: Zwift Ride V2 Smart Frame and Zwift Cog v2
  • Needs a compatible smart trainer, sold separately; front leg riser foot included for height alignment
  • Works with Zwift Cog v1 and v2, and with the Zwift and ROUVY apps
  • Shifting, steering and UI control run over Bluetooth; ANT+ dongles are not supported
  • Apple TV users pair through the Zwift Companion app, which works around the limited Bluetooth connections
Complete your setup
Add accessories, ships with your Zwift Ride V1 Smart Frame
Zwift Ride V1 Smart Frame only
Total $1,400.00
  • Quiet & Compact
    Zwift Ride Smart Frame is powerful, yet keeps a low profile: it takes up less space than a traditional bike and trainer setup, and can be easily packed away and set back up again if needed.
  • Simple Setup
    Set up the Zwift Ride Smart Frame easily on your own. All you need is the included Frame Key and a compatible smart trainer.
  • Easily Adjustable
    Zwift Ride Smart Frame is easily adjustable for riders between 5’ and 6’ 6”. All it takes to adjust the bike and share the fun is the Frame Key stored in the bike frame.
  • Effortless Control
    Control Zwift easily from your handlebars. Queue workouts, use PowerUps, and send RideOns—all without pausing your ride.
  • Always Ready
    Designed for the home, Zwift Ride Smart Frame is ready to ride whenever you are.
  • Smooth Shifting
    Experience flawless, silent gear shifting with a customizable setup, ensuring you're always in the right gear for any route.
What’s Included
  • ZWIFT RIDE Smart Frame
  • Zwift Cog
Tech Specs
  • Rider Fit Specs
    • Rider Fit Range: 152 - 198 cm
    • Saddle Height Min-Max: 59.9 - 86.5 cm (center bottom bracket to top of saddle)
    • Stepover Height: 76.4 cm
    • Max Rider Weight: 120 kg
    • Crank Length: 170mm
  • Product Dimensions and Frame Specs
    • Product Dimensions: 110 cm L x 43.2 cm W
    • Drivetrain: Chain (KMC Z1 narrow 3/32" width)
    • Pedals: Flat Included (compatible with all standard road and mountain pedals)
    • Saddle: 160mm W x 245mm L
  • Additional Handlebar Specs
    • Handlebar Height Min-Max: 86.3 - 102.4 cm
    • Handlebar Width: 42 cm (center to center)
    • Integrated rechargeable controllers with 20 hrs. Per charge
    • Handlebar Controller Power: Built-in rechargeable lithium-ion battery (1050 mAh)
    • Handlebar Controller Power requirements: USB-A, 5v, 1A
  • Compatibility
    • Compatible with Zwift Cog v1 & Zwift Cog v2. Updated Zwift Cog v2 included with purchase.
    • Update to latest firmware using manufacturer’s app.
    • Front Leg Riser Foot included for trainer height alignment
    • Compatible with Zwift and ROUVY apps
  • Connectivity
    • Not compatible with ANT+ dongles
    • In-game shifting, steering and UI control via handlebars are wirelessly transmitted via Bluetooth
    • Apple TV users are required to pair through Zwift Companion app as a bridge to address the limited number of Bluetooth connections
