$699.95
The Wahoo KICKR SNAP makes indoor cycling a "snap!" It's a convenient, easy to set-up wheel-on indoor bicycle trainer with the realistic ride experience for which Wahoo bike trainers are known.
  • FEATURES
    • +/- 3% power accuracy
    • Wheel-on design enables easy set-up
    • Measures speed, distance, and power data
    • View More
  • SPECS
    • Maximum Power Output: 1500W
    • 12% Simulated Incline
    • ANT+, ANT+ FE-C, and Bluetooth Connectivity
    • View More
  • SETUP
    • Ready to ride right out of the box.
    • Includes quick release skewer and wheel block.
    • Setup Instructions
  • View More
  • View More
RIDE THE REVOLUTION
This wheel-on indoor bike trainer is compatible with KICKR Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup to make your smart bike trainer experience next level immersive.
KICKR SNAP Benefits
Controlled Resistance
When connected to your smartphone, tablet, computer or GPS bike computer, KICKR SNAP automatically sets your resistance to create a realistic ride feel to cycling outdoors.
Optimized flywheel technology
KICKR SNAP features a 10.5lb flywheel engineered to provide riders with the precise inertia needed to recreate an outdoor ride feel while training on a wheel-on bike trainer.
Set-up is a SNAP
The wheel-on design of KICKR SNAP makes it easy to turn your road, mountain, or TT bike into a powerful indoor bike trainer.
Professional grade durability
Robust steel construction ensures the KICKR SNAP stays in place while you crank out the watts and stands up to years of heavy use.
KICKR SNAP Benefits
CONTROLLED RESISTANCE
OPTIMIZED FLYWHEEL TECHNOLOGY
SET-UP IS A SNAP
PROFESSIONAL GRADE DURABILITY
SNAP TO IT.
The control, accuracy, and connectivity of the legendary KICKR indoor bike trainer in a convenient wheel-on design.
MAX GRADE SIMULATION
10% 12% 16% 20%
MAX POWER (WATTS)
1500w 1800w 2200w
KICKR SNAP FEATURES
KICKR SNAP features a 10.5lb flywheel engineered to provide riders with the precise inertia needed to recreate an outdoor ride feel while training indoors.
When connected to your smartphone, tablet, computer or gps bike computer, the KICKR SNAP indoor bike trainer automatically sets and adjusts your resistance based on the software or route.
DISC BRAKE CLEARANCE
The design of the KICKR SNAP ensures clearance for flat mount and disc brake equipped bikes.
ECOSYSTEM COMPATIBLE
KICKR SNAP is compatible with KICKR Bike Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup for your training needs.
All Wahoo indoor bike trainers and smart bikes come with a trial to Wahoo X, giving you access to SYSTM, a comprehensive collection of structured workouts and training plans, tailored towards your fitness objectives.
KICKR SNAP SPECS
TECH SPECS
  • Maximum Power Output: 1500 Watts
  • Maximum Simulated Grade: 12%
  • Product Weight: 38 lb / 17 kg
  • Drivetrain: N/A
  • Power Accuracy: +/-3%
  • Cassette: N/A
  • Hub Types: 130/135mm QR, 12x142
  • Adapters: 130/135mm QR (included), 12x142 Thru-Axle (sold separately)
WHAT’S IN THE BOX?
  • KICKR SNAP indoor bike trainer
  • AC Power Adapter
  • Quick Release Skewer
  • Front Wheel Block
SUPPORTED DEVICES
BIKE COMPATIBILITY
BIKE COMPATIBILITY CHECK
Will my bike fit on the KICKR SNAP? Find out here.
Start
