    $699.95
    The Wahoo KICKR SNAP makes indoor cycling a "snap!" It's a convenient, easy to set-up wheel-on indoor bicycle trainer with the realistic ride experience for which Wahoo bike trainers are known.
    • FEATURES
      • +/- 3% power accuracy
      • Wheel-on design enables easy set-up
      • Measures speed, distance, and power data
      • View More
    • SPECS
      • Maximum Power Output: 1500W
      • 12% Simulated Incline
      • ANT+, ANT+ FE-C, and Bluetooth Connectivity
      • View More
    • SETUP
      • Ready to ride right out of the box.
      • Includes quick release skewer and wheel block.
      • Setup Instructions
    • View More
    • View More
    RECOMMENDED ADD-ONS
    WAHOO X Annual Membership
    WAHOO X ANNUAL MEMBERSHIP
    $229.00
    No matter how you choose to ride or train, Wahoo X is the easiest way to get all your favorite training experiences for one incredible price.
    KICKR SNAP 142x12 Thru Axle Adapter
    KICKR SNAP 12x142 THRU AXLE ADAPTER
    $99.95
    For all editions of the Wahoo KICKR SNAP
    KICKR Headwind Bluetooth Fan
    KICKR HEADWIND BLUETOOTH FAN
    $449.95
    This smart fan adjusts to match your riding speed or heart rate, or select manual settings.
    Wahoo KICKR Trainer FloorMat
    KICKR TRAINER FLOORMAT
    $129.95
    RIDE THE REVOLUTION
    This wheel-on indoor bike trainer is compatible with KICKR Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup to make your smart bike trainer experience next level immersive.
    SNAP TO IT.
    The control, accuracy, and connectivity of the legendary KICKR indoor bike trainer in a convenient wheel-on design.
    MAX GRADE SIMULATION
    10% 12% 16% 20%
    MAX POWER (WATTS)
    1500w 1800w 2200w
    KICKR SNAP FEATURES
    OPTIMIZED FLYWHEEL TECHNOLOGY
    KICKR SNAP features a 10.5lb flywheel engineered to provide riders with the precise inertia needed to recreate an outdoor ride feel while training indoors.
    CONTROLLED RESISTANCE
    When connected to your smartphone, tablet, computer or gps bike computer, the KICKR SNAP indoor bike trainer automatically sets and adjusts your resistance based on the software or route.
    DISC BRAKE CLEARANCE
    The design of the KICKR SNAP ensures clearance for flat mount and disc brake equipped bikes.
    ECOSYSTEM COMPATIBLE
    KICKR SNAP is compatible with KICKR Bike Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup for your training needs.
    All Wahoo indoor bike trainers and smart bikes come with a trial to Wahoo X, giving you access to SYSTM, a comprehensive collection of structured workouts and training plans, tailored towards your fitness objectives.
    KICKR SNAP SPECS
    TECH SPECS
    • Maximum Power Output: 1500 Watts
    • Maximum Simulated Grade: 12%
    • Product Weight: 38 lb / 17 kg
    • Drivetrain: N/A
    • Power Accuracy: +/-3%
    • Cassette: N/A
    • Hub Types: 130/135mm QR, 12x142
    • Adapters: 130/135mm QR (included), 12x142 Thru-Axle (sold separately)
    WHAT’S IN THE BOX?
    • KICKR SNAP indoor bike trainer
    • AC Power Adapter
    • Quick Release Skewer
    • Front Wheel Block
    SUPPORTED DEVICES
    BIKE COMPATIBILITY
    BIKE COMPATIBILITY CHECK
    Will my bike fit on the KICKR SNAP? Find out here.
    Start
    Awards
