KICKR ROLLR with 1-Year Zwift Membership
$1,159.95
Better together. KICKR ROLLR makes it easy to transition quickly from outdoor riding to indoor training. The dual-roller design frees the rear wheel to move naturally, providing an experience that feels more like riding outdoors. Purchase KICKR ROLLR with a 1-year Zwift membership for indoor cycling fun with serious fitness results.
KICKR ROLLR can be used as a virtual power source in Zwift with limitations. For dynamic resistance in Zwift, a power meter is required.
Purchase includes a 1-year membership to Zwift for €100, a €49.99 savings. Purchase includes a 1-year membership to Zwift for $100, a $49.99 savings. Purchase includes a 1-year membership to Zwift for £100, a £29.99 savings. Purchase includes a 1-year membership to Zwift for $140, a $49.99 savings. Purchase includes a 1-year membership to Zwift for $160, a $59.99 savings. Purchase includes a 1-year membership to Zwift. Membership requires Zwift account and auto-renews after 12 months at €149.99, $149.99, £129.99, $189.99, $219.99, ¥15,000, unless cancelled.
Billing information required to redeem. Terms apply.
  • FEATURES
    • Measures speed and distance. Power meter required for power and cadence data
    • View More
  • SPECS
    • Maximum Power Output: 1500W
    • 10% Simulated Incline
    • View More
  • SETUP
    • Some assembly required
    • Compatible with all drivetrains
    • Smooth tread pattern recommended
    • Setup Instructions
  • View More
  • View More
RECOMMENDED ADD-ONS
POWRLINK ZERO DUAL-SIDED POWER PEDALS
$1,499.95
Stainless steel dual-sided bike pedal and cleat system offer a customized fit for peak power transfer.
KICKR Headwind Bluetooth Fan
KICKR HEADWIND BLUETOOTH FAN
$449.95
This smart fan adjusts to match your riding speed or heart rate, or select manual settings.
Wahoo KICKR Trainer FloorMat
KICKR TRAINER FLOORMAT
$129.95
Wahoo Fitness Standing Desk Extended
KICKR DESK
$449.95
Sturdy and slip-resistant surface keeps everything in place and within reach for your ride.
RIDE THE REVOLUTION
KICKR ROLLR smart bike roller is compatible with bike trainer accessories, including the KICKR DESK and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup to make your smart bike experience next level immersive.
READY. SET. ROLL.
KICKR ROLLR's convenient design makes it easy to transition your ride from outdoors to indoors. Simply adjust the wheel base, secure your bike and ride.
MAX GRADE SIMULATION
10% 12% 16% 20%
MAX POWER (WATTS)
1500w 1800w 2200w
KICKR ROLLR FEATURES
AWARD WINNING DUAL ROLLER DESIGN
The dual-roller design frees up the rear wheel to move naturally, providing an experience that feels more like riding outdoors while reducing tire slip, no matter how much power you put to the pedals. This unique design has been awarded:
  • Fit Sport Design Award Winner 2023
  • Good Design Award Winner 2023
  • Fast Company Innovation by Design 2023 Award Winner
  • IDA Design Awards, 2023 Gold
  • IDEA (International Design Excellence Awards) 2023 Silver Winner
DUAL ROLLER DESIGN
CONTROLLED RESISTANCE
When connected to an external power meter (not included), KICKR ROLLR provides controlled resistance in level, ERG and simulated modes. Without a connected power meter, the smart bike roller delivers consistent resistance and broadcasts speed metrics.
QUICK-ADJUST WHEELBASE CLAMP
Quickly transition from outdoor rides to indoor cycling. Simply open the quick-adjust wheelbase clamp and adjust the wheel chocks to match your bike's wheelbase: ideal for riders with multiple bikes or households with multiple riders.
POWER METER CONNECT
Connect Wahoo POWRLINK ZERO power pedals or other ANT+ power meters to KICKR ROLLR to get the benefits of training with power. ROLLR provides power readings to within +/-1% accuracy of the power meter, allowing you to train with the same precision, indoors and outdoors.
ECOSYSTEM COMPATIBLE
KICKR ROLLR bike roller is compatible with KICKR Trainer Accessories, including the KICKR HEADWIND Smart Fan and KICKR Desk, allowing you to build the ideal setup for your indoor cycling needs.
KICKR ROLLR SPECS
TECH SPECS
  • Maximum Power Output: 1500 Watts
  • Maximum Simulated Grade: 10%
  • Product Weight: 50 lb / 23 kg
  • Drivetrain: N/A
  • Power Accuracy: Within +/-1% of external power meter (not included)
  • Connectivity: ANT+, ANT+ FE-C, Bluetooth, Direct Connect
  • Cassette: N/A
  • Hub Types: N/A
  • Adapters: N/A
WHAT’S IN THE BOX?
  • AC Power Adapter
  • Owner's Manual
SUPPORTED DEVICES
BIKE COMPATIBILITY
BIKE COMPATIBILITY CHECK
Start
