KICKR SNAP
SMART BIKE TRAINER
BUY NOW
THE ULTIMATE INDOOR
WHEEL-ON SMART TRAINER
The convenient, easy-to-use KICKR SNAP is the perfect companion for an entry-level cyclist or weekend warrior. Featuring the legendary KICKR flywheel technology, in an approachable wheel-on design, KICKR SNAP indoor trainer delivers the same resistance and realistic ride feel experienced cycling outdoors.
TRAIN WITH CONVENIENCE
The same control, accuracy, and connectivity found in the legendary KICKR, but in a convenient wheel-on design that makes training a snap!
BUY NOW
CONVENIENT AND EASY SETUP
KICKR SNAP’s wheel-on design makes it easy to turn your road, mountain, or TT bike into a powerful indoor smart trainer, plus the Wahoo Fitness app offers guided set-up instructions to fine tune your ride and start training in just minutes.
ECOSYSTEM COMPATIBLE
KICKR SNAP is compatible with KICKR Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup for your training needs.
CONTROLLED RESISTANCE
KICKR SNAP Bike Trainer uses your smartphone, tablet, computer or GPS device to control resistance and provide a reliable power measurement so you can monitor and adjust your intensity.
STABILITY
Made from high strength carbon steel and featuring a wide stance, the SNAP indoor trainer is designed to keep its feet firmly planted on the floor and your bike securely locked in so you can train with confidence.
TRAIN YOUR WAY
KICKR SNAP pairs seamlessly with Wahoo KICKR Trainer Accessories, ELEMNT Bike Computers, and RPM Sensors, along with the most popular apps and software to create the most immersive and engaging indoor training environment.
SHOP TRAINER ACCESSORIES VIEW THE ECOSYSTEM
+/-3%
ACCURACY
RELIABLE POWER
1,500
WATTS
MAX POWER
TRAIN WITH CONFIDENCE
REALISTIC RIDE FEEL
The legendary flywheel technology and tested algorithms emulate the power and experience of riding outdoors, especially when using virtual training platforms like The Sufferfest or Zwift.
HIGH-INERTIA FLYWHEEL
Engineered for reliability, the 10.5 pound heavyweight flywheel in the KICKR SNAP provides precise inertia needed to recreate an outdoor ride feel while training indoors.
KICKR SNAP automatically responds and adjusts resistance via your favorite app or software to simulate grade changes of up to a 12% incline.
PROFESSIONAL-GRADE CONSTRUCTION
Built from a robust steel construction, KICKR SNAP stands up to years of heavy use from all types of cyclists.
ADVANCED CONNECTIVITY
ANT+ and Bluetooth® capabilities allow the KICKR SNAP to connect to smartphones, GPS devices, and FE-C enabled devices or applications.
RIDE THE REVOLUTION
SHOP TRAINERS VIEW THE ECOSYSTEM
FREE 2 MONTH SUBSCRIPTION OF WAHOO SUF TRAINING WITH YOUR SMART TRAINER PURCHASE.
MORE THAN FASTER
Designed by world-class sports scientists, the Wahoo SUF Training app combines personalized workouts with yoga, mental and strength training to help you take your performance to the next level. One app. Everything you need to become stronger, faster and more focused.
Learn more
  • CYCLING
    Complete library of structured workouts designed by the world’s best coaches. The exclusive Four-Dimensional Power® platform personalizes all of your performance targets for the most effective workouts available.
  • YOGA
    Sessions to help build strength and flexibility in ways that translate directly to more speed and power on the bike. Enhance your powers of recovery and improve your range of motion to help avoid injury.
  • STRENGTH
    Easy to follow bodyweight-based program designed specifically for cyclists to build functional strength and turbo-charge your power and endurance on the bike.
  • MENTAL
    Train your brain and build mental toughness to help you get the most out of your training & deliver when it really counts.
WORKS WITH THE MOST APPS
WAHOO SUF TRAINING
LEARN MORE
ZWIFT
LEARN MORE
STRAVA
LEARN MORE
TRAINERROAD
LEARN MORE
FULGAZ
LEARN MORE
ROUVY
LEARN MORE
