KICKR CORE Smart Bike Trainer
$899.95
KICKR CORE smart bike trainers deliver a realistic, accurate, and quiet indoor cycling experience. Designed and built with durability and stability in mind to withstand your hardest rides - even if your legs don't.
  • +/- 2% power accuracy
  • Measures speed, distance, power, and cadence data
  • View More
  • Maximum Power Output: 1800W
  • 16% Simulated Incline
  • ANT+, ANT+ FE-C, and Bluetooth Connectivity
  • View More
This product is out of stock
RECOMMENDED ADD-ONS
WAHOO X Annual Membership
WAHOO X ANNUAL MEMBERSHIP
$229.00
No matter how you choose to ride or train, Wahoo X is the easiest way to get all your favorite training experiences for one incredible price.
11 Speed Cassette
11 SPEED CASSETTE
$69.95
Complete your KICKR CORE with an 11 speed cassette (11-28T). Compatible with SRAM and Shimano.
10 Speed Cassette
10 SPEED CASSETTE
$69.95
Complete your KICKR CORE with a 10 speed cassette (11-28T). Compatible with SRAM and Shimano.
Wahoo KICKR Trainer FloorMat
KICKR TRAINER FLOORMAT
$129.95
RIDE THE REVOLUTION
This smart bike trainer is compatible with KICKR Trainer Accessories, including the KICKR CLIMB Grade Simulator and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup to make your smart bike trainer experience next level immersive.
KICKR CORE Smart Trainer
YOUR RIDE. YOUR WAY.
KICKR CORE smart trainer includes a pre-installed cassette to match the gears on your bike. Choose from 8, 9, 10, 11, or 12-speed options, and you'll be ready to ride.
KICKR CORE is compatible with 8, 9, 10, 11 and 12 speed cassettes, giving you the flexibility to add your preferred cassette to the smart bike trainer, so that you can fully mimic your outdoor groupset.
MAX GRADE SIMULATION
10% 12% 16% 20%
MAX POWER (WATTS)
1500w 1800w 2200w
KICKR CORE FEATURES
KICKR TO THE CORE
CONTROLLED RESISTANCE
When connected to your smartphone, tablet, computer or GPS bike computer, KICKR CORE smart bike trainer automatically controls your resistance based on the software or route.
POWER, SPEED, DISTANCE and CADENCE
PROFESSIONAL GRADE DURABILITY
KICKR CORE SPECS
TECH SPECS
  • Maximum Power Output: 1800 Watts
  • Product Weight: 40 lb / 18 kg
  • Drivetrain: Belt Drive
  • Power Accuracy: +/-2%
  • Connectivity: ANT+, ANT+ FE-C, and up to three Bluetooth Connections
  • Cassette: Not Included
  • KICKR CORE smart trainer includes a pre-installed cassette to match the gears on your bike. Choose from 8, 9, 10, 11, or 12-speed options, and you'll be ready to ride.
WHAT’S IN THE BOX?
  • KICKR CORE Smart Bike Trainer
  • Rear Leg
  • Front Leg
  • Nuts (x4)
  • Bolts (x4)
  • Hex Tool
  • Drive Side Adapter for 12x142 and 12x148 Thru Axle
  • Reversible hub spacer for Thru Axle
  • AC Power Adapter
  • Quick Release Skewer
  • 1.8mm Cassette Spacer
SUPPORTED DEVICES
BIKE COMPATIBILITY
BIKE COMPATIBILITY CHECK
Start
