The Ultimate Indoor Bike
Wahoo KICKR smart bike in a cycling studio setting
Ride Real. Ride Ready.
Bring Your Ride Inside
  • Always Ready
  • True Fit
  • Real-Time Response
  • Gear Configuration
  • Virtual Shifting
    Wahoo KICKR BIKE PRO
    Wahoo App icon Compatible with Wahoo App
    Wi-Fi, Bluetooth, and ANT+
    Max Power Wattage 2500 Watts
    93 lb
    Wahoo KICKR BIKE SHIFT
    Max Power Wattage 2200 Watts
    79 lb
    Wahoo App logo
    Your KICKR Ride Companion
    FAQ
    The KICKR BIKE PRO and KICKR BIKE SHIFT can be adjusted at 5 touch points across the bike. The Wahoo app walks you through fit setup based off external bike fit numbers or through inputting your height and inseam measurements. It's easily adjustable for riders between 5' and 6'6" tall.
    The KICKR BIKE PRO and KICKR BIKE SHIFT stock road drop handlebars are compatible with most aftermarket clip-on/bolt-on aerobars, offering a 31.8 mm diameter clamping surface that is 100 mm wide overall.  The BIKE's stock stem clamp is 40 mm wide.  There is an available clamping surface from 20-50mm from the handlebar's center point on both sides.
