$99.95
Step, snap, and ride with confidence using the SPEEDPLAY easy tension walkable road cleat. While retaining all the advantages of the SPEEDPLAY Bike Pedal System, the easy action spring mechanism makes it a breeze to clip in and out. Enhanced walkability and adjustability make this bike cleat comfortable and functional for every level of cyclist.
EASY ACTION SPRING
The Easy Tension walkable bike cleat utilizes an easy action spring mechanism for a simpler pedal engagement experience for those smaller or more novice riders.
ENHANCED WALKABILITY
The dimpled, low profile design and rubberized texture allow for better traction and enhanced walkability.
3 AXIS ADJUSTABILITY
Independent 3 axis adjustability to optimize fit and enhance performance through better biomechanics on the bike.
IDEAL FORE & AFT PLACEMENT
Up to 14mm of fore/aft (forward & back movement) adjustability to lock the cleat base plate into place on the bottom side of the shoe.
PRECISE SIDE TO SIDE TUNING
With the left/right adjustment you can further dial in your cleat placement. The cleat spring housing plat allows for up to 8mm of side to side flexibility.
ROTATIONAL FREE FLOAT
1 - 15 degrees of micro-adjustable free float to dial in the perfect amount of movement.
SPRING TECHNOLOGY
The SPEEDPLAY Easy Tension cleat utilizes spring technology to allow for an easy and effective clipless experience.
Specs
Product Overview
Reviews
