Overview Reviews
KICKR SNAP 12x142 Thru Axle Adapter
$114.95
For all editions of the Wahoo KICKR SNAP
KICKR SNAP 12x142 Thru Axle Adapter is rated 3.3 out of 5 by 26.
  • y_2019, m_4, d_24, h_15
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.12
  • cp_1, bvpage1
  • co_hasreviews, tv_1, tr_25
  • loc_en_US, sid_WFSNAP142, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 32.07ms
$114.95
  • Free Shipping On Orders Over $99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Product Overview
Our thru-axle kit comes with everything you need to mount most 12x142 thru-axle bikes on your KICKR SNAP indoor trainer. This accessory will work with all editions of the Wahoo KICKR SNAP. It includes the following:
  • Threaded axle spacer M12 x 1.75 Coarse
  • M12 x 1.5 Medium
  • M12 x 1.0 Fine
  • End Cap
Note: This kit is for 12x142 bikes only. Not compatible with 12x135, 12x148, or any other thru-axle system. Please watch the SNAP adapter installation video before attempting to install yourself. If you have any questions, don't hesitate to contact us!
Rated 5 out of 5 by from Worked perfect, just what I was looking for! I bought this for the kicker snap trainer specifically for a womens specialized ruby bike with the newer rear one way skewer. Works perfectly on this trainer.
Date published: 2019-04-11
Rated 5 out of 5 by from It Works correctly I purchased this for my Trek Domane with thru axle. It works perfectly. I know that this set is a little more expensive than others, but it covers all 12mm thru axles I know about. The bike is secure in the Kickr Snap, that is the most important part.
Date published: 2018-03-12
Rated 5 out of 5 by from Let me ride my thru-axle bike on the SNAP! I recently purchased a Cervelo R3 with disc brakes, which has a through axle and therefore doesn't fit the SNAP. After trying two other adapters. This one fit and works and I was able to donate my old bike to a good cause.
Date published: 2016-08-01
Rated 5 out of 5 by from Brian H. Davis San Francisco, CA Outstanding product it was immediately adaptable to my Specialized Carbon HT 29er World Cup Elite Mountain Bike. The 142 Adapter was easy to install and my indoor set-up for riding was complete within 3 minutes.
Date published: 2016-03-12
Rated 5 out of 5 by from Wonderful Fit with Trek Domane 4.3 Disc Very simple install and perfect fit with my Trek Domane thru-Axel road bike. I needed a trainer that gave the option to mount a thru-Axel 142 bike, and wahoo delivered once again!!!
Date published: 2016-01-27
Rated 5 out of 5 by from Works Great Adapter cup is easy to install on the trainer side. Three different axle options are nice so no bike is left out. The only downside to this is that I thought it was a bit pricey for a few axles and the aluminum cup. But it works well and is of high quality so you get what you pay for.
Date published: 2016-01-19
Rated 4 out of 5 by from Works Perfect! If you have a bike with a thru axle there is no way to get around using your Wahoo Snap without the adaptor and their thru axle. My local bike shop said the Kinetic thru axle would work but it did not. The only reason I am giving this product a 4 and not a 5 is because it is very pricey. Also, I feel as if the price could be reduced by only purchasing the 1 axle that works with your particular bike instead of having to purchase the 3 axles.
Date published: 2018-07-26
Rated 4 out of 5 by from Must have item for a through axle frame Bought a new road bike and needed this to attach it to my Kickr Snap, install was easy and it’s working fine. Price was a little high since it has three different threaded axles but what can you do. At least I know I’m covered if I switch bike brands again.
Date published: 2018-03-28
  • cp_1, bvpage1
  • CLOUD, getReviews, 2.46ms
Product Overview
  • M12 x 1.5 Medium
  • M12 x 1.0 Fine
  • End Cap
For more info, see Faq
Specs
Reviews
