Get everything you need to train to be the King of the Mountain! Our KICKR K.O.M. bundle is designed for those who want to take their indoor training to the next level - literally - using a Wahoo KICKR Smart Trainer and the KICKR CLIMB.
The Wahoo KICKR provides the ultimate indoor cycling experience with a realistic road feel, power accuracy, and the most software training options. The KICKR CLIMB is designed to elevate your training with the addition of physical grade changes, both ascents and descents.
PLEASE NOTE: The KICKR only ships to select countries. Signature required for delivery of all trainer shipments.
MOST REALISTIC RIDE FEEL |
The KICKR's heavyweight flywheel and fine-tuned responsive resistance, paired with the KICKR CLIMB's real-time ascents ( 20%) and descents (-10%), recreate an unparalleled outdoor ride feel. |
+/- 1% POWER ACCURACY |
The Wahoo KICKR bike trainer provides accurate power measurement of +/- 1% and generates up to 2200W of resistance. |
POWER POSITION |
Training on a KICKR with KICKR CLIMB allows you to more naturally change position on the bike, engage climbing muscles, and improve pedaling technique to become a more efficient and powerful climber. |
SEAMLESS CONNECTIVITY |
Using proximity pairing via Bluetooth, KICKR CLIMB connects within seconds to the KICKR Smart Trainer. Offering a robust 2.4 GHz Wi-Fi connection, up to 3 Bluetooth Connections, a direct connect port and ANT+/ANT+FE-C compatibility, KICKR smart trainers pair to most devices and applications so you have the most control over your training and ride data. |
WAHOO ECOSYSTEM COMPATIBLE |
KICKR Smart Trainer + KICKR CLIMB is just the start of your ultimate training experience. KICKR is compatible with the entire Wahoo ecosystem of training devices and software to help build a better athlete in you. |
BIKE COMPATIBILITY |
Both KICKR and KICKR CLIMB are compatible with a wide range of bikes. The KICKR features 12x142 and 12x148 thru-axle compatibility in addition to standard 130/135mm quick release. CLIMB supports standard quick release, 12x100, 15x100, and 15x110 thru-axle hubs. |
Wahoo KICKR |
Wahoo KICKR CLIMB |
iOS 16 or newer
Please visit our support site to check for Android compatibility.
BTLE enabled or pair with an ANT+ dongle
