TICKR FIT heart rate armband uses optical heart rate technology to provide accurate heart rate and calorie burn data in the most comfortable form factor yet! Equipped with Bluetooth and ANT+ technology to seamlessly pair with fitness apps, smartphones, and GPS bike computers and watches. Worn on the forearm, the TICKR FIT heart rate monitor comes with an adjustable band that is designed for your most grueling workouts including running, cycling, fitness classes, and more. TICKR FIT has water-resistant technology and a rechargeable battery that lasts up to 30 hours.
DUAL-BAND ANT+ AND BLUETOOTH TECHNOLOGY |
Both Bluetooth and ANT+ capabilities allow for a wireless connection to both smartphones and GPS bike computers and watches. Note: Does not serve as an ANT+ bridge. |
REAL-TIME HEART RATE, CALORIE, AND WORKOUT DURATION TRACKING |
TICKR FIT measures vital workout metrics, including heart rate, calorie burn, and workout duration in real-time with the Wahoo Fitness app. These metrics can also be sent to compatible third-party apps that track these metrics. |
LED INDICATOR LIGHT |
One LED light shows visual confirmation of the TICKR connection status via Bluetooth and / or ANT+: searching for a connections, connecting, and reading heart rate. |
USB RECHARGEABLE BATTERY |
Includes a USB rechargeable battery with up to 30 hours of battery life. |
ADVANCED PERFORMANCE MATERIAL STRAP |
Made from advanced performance materials, TICKR FIT is designed to comfortably fit around your arm, yet fit securely during intense activity. |
TWO ADJUSTABLE BANDS INCLUDED |
TICKR FIT comes with 2 adjustable bands (small and large size) in the box. |
APPLE WATCH AND APPLE TV INTEGRATION |
Connect directly via Bluetooth to your Apple Watch or Apple TV as another option for gathering heart rate data while you workout. |
THIRD PARTY APP COMPATIBILITY |
Works seamlessly with over 50 apps - including SYSTM, Zwift, Peloton for cycling and Runkeeper and MapMyRun for running. |
TICKR FIT connects to smartphones, GPS watches & bike computers, and it verifies the connection by using convenient LED lights.
TICKR FIT uses the latest in optical heart rate technology to give you accurate heart rate and calorie burn data for up to 30 hours.
Made from advanced performance materials, TICKR FIT’s band is designed to fit comfortably around your arm, yet fit securely during intense activity.
Click here for TICKR FIT instructions.
iOS 16 or newer
Please visit our support site to check for Android compatibility.
