$9.99 shipping on all orders*!
Overview Features Reviews
Wahoo RPM Speed and Cadence Sensors Bundle
$89.95
More Views
Wireless Speed and Cadence Cycling Sensors
SKU# WFRPMC
$89.95
  • $9.99 Shipping On All Orders
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
All you need for cycling data, all together at once! The Wahoo RPM Speed and Cadence sensors are both a sleek, wireless, and magnet-less solution. Each mounts easily to your bike and the Bluetooth Smart and ANT+ duel band technology allows you to connect and display data on both smartphone and bike computers.
RPM Speed Features
Discover all the nitty gritty details about the RPM speed sensor
RPM Cadence Features
Discover all the nitty gritty details about the RPM cadence sensor
Click here for RPM Cadence instructions
Click here for RPM Speed Instructions
Specs
For both RPM Cadence and RPM Speed
Dimensions (LxWxH): 1.25" x.75" x 1"
Weight: 7 grams (without mount)
Battery: CR2032
Battery Life: Up to 12 months
Water Rating: IPX7 (waterproof up to 5 ft)
Wireless Signal Strength: Up to 10 feet
Wahoo RPM Speed and Cadence Sensors Bundle is rated 4.3 out of 5 by 79.
Rated 4 out of 5 by from Good Product...Shipping Slow Purchased 21 May 2017. Units arrived in 6 days. The TIKR and CADENCE sensors performed flawlessly and paired easily. The SPEED sensor would not stay paired properly. Contacted Wahoo customer service on 27 May to report the problem. The following Monday (30 May) Melinda S. sent a replacement sensor. Received the replacement 6 days later and it worked. I like the sensors and the Wahoo Fitness App (Android version). Will recommend added features via feedback to customer service. Excellent customer service. Slow delivery on the product.
Date published: 2017-06-13
Rated 5 out of 5 by from Never fails! I have 3 bikes with the Wahoo RPM and speed sensors. Never fail and easy connection to my ELEMNT.
Date published: 2017-06-04
Rated 1 out of 5 by from Disapointing I bought this a little over a month ago have been able to use it twice, have gone through 5 sets of batteries first set was dead on arrival, Batteries tested at 3.39 volts dc installed in sensors and they show as connected and 24 hours later they no longer show as connected after removing batteries they test at 2 volts. Was promised new sensors on May 14th and have heard nothing sense,
Date published: 2017-05-22
Rated 4 out of 5 by from Great deal Both sensors are easy to install and syncronize with the wahoo element or app. Two things you have to be care of 1. Speed sensor fits a little large on the free wheel hub 2. Speed sensor battery came installed and already dead. I have to buy a new one without any use.
Date published: 2017-05-10
Rated 5 out of 5 by from just does what needs to be done Bought as replacement for Blue SC, is a lot easier to install. Works great.
Date published: 2017-04-29
Rated 4 out of 5 by from Why only Apple.. Has been happy with the sensors and ease it is to install, but a huge bummer that you can't use autopause on it when you are using Android, but being told it works with Apple. Hopefully will quick get this upgraded.
Date published: 2017-04-19
Rated 5 out of 5 by from Easy as pie! It's so easy to install and they work like a dream. I bought them when I purchased the new element bolt and I've been very happy ever since.
Date published: 2017-04-15
Rated 5 out of 5 by from Works great I bought this bundle after purchasing and returning several other products for speed and cadence. All of those products had issues syncing up with my phone. Not the Wahoo parts. They worked PERFECT. I downloaded the wahoo app on my Note 3 and put the sensors in the bike. Took about 5 minutes total time. Spun the crank on the bike, sensors woke up and phone connected. There was an update for the cadence sensor which the wahoo app automatically downloaded and installed. Next over to strava. Once again no problem. Strava connected to the sensors and worked perfect. These wahoo sensors are wonderful, simple, easy to setup and work!! No need to fool sound with the sensors from other companies. Just get these and get data. Also install simple and easy. Speed is in a rubber mount and simply loops over the hub. Cadence is in this nifty mount that sticks in place using the included 3M adhesive. I added and zip tie for backup. 200+miles so far with no issues.
Date published: 2017-04-12
  • y_2017, m_6, d_27, h_15
  • cp_1, bvpage1
  • co_hasreviews, tv_5, tr_74
  • loc_en_US, sid_WFRPMC, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 75.54ms
Product Overview
RPM Speed Features
For more info, see Faq
Specs
Battery: CR2032
Reviews
